Exporting Just ONE Annotation Set
wjmdes
I am trying to create marketing sheets on my plans and have a new annotation set to do this.  Is it possible to just export and import just this one set.  Copying complete annotations sets to previous work could be a disaster.
Not AFAIK what I have done is moved part of an annoset- but if you copy -plain text, dimension(s), and cad line from a plan using one annoset the defaults from those sill be added to the new plan. It at least cuts down the work. Rich Text doesn't work and I have not tried the other categories since these are the ones I usually want to start with. And of course you can export import individual layersets.
1 hour ago, Alaskan_Son said:
See if this thread helps you out at all…
So basically delete all anno sets in a file but one, export, and then you are importing just the one. That was too simple....Thanks
