Schedule Symbol Line weights
Member Statistics
Similar Content
By marlem2000
Hi, everybody
I would like to know how you edit symbols or CAD blocks.
I don’t have much experience creating my own objects so I usually download them from pages like 3D Warehouse.
Most of the times I need to make changes or remove elements included in these objects so I just load the symbol, go to Edit CAD block and try to modify what I need in the CAD Block window.
When the object is ready, I just add it to the library, but when I try to reload again the symbol previously created I can’t see it in the 3D view.
I’m sure I’m missing some steps or, probably, I can’t understand how symbols work.
Many thanks for the help!
By Renerabbitt
Separating Sale items from free items from the popular FREE SYMBOLS AND CONTENT
All items can be purchased from the SHOP
Want free items? I love giving away things to help you succeed in this software, just click on the link above for the symbols and content thread for free stuff!
By BlackDiamond
Hi,
I'm trying to update my electrical schedule with all the fixtures I'm using on a plan. Some of the electrical symbols require a wall to be able to be placed on the plan.
How can I get a copy of the symbol to place in my schedule without having to add a wall to do it?
Thanks
By PJS-59
I like HO Railroads. I am getting started on a new layout and want to build HO Scale Houses and buildings. I figured I could create the building plan with Chief Architect and print the elevations with Scale Dimensions to use for cutting and building the scale model. I have created the first building, was able to set the print scale for HO (1/7" = 1') and print a "Full Size" elevation that I can use a ruler to get measurements from, or use as a template and cut printout and balsa wood together.
Can anyone give me any ideas on how to show scale dimensions? Ex house is 50' wide, HO Scale would be 7.14". a 7' high Door would be 1" high on HO Scale model.
I have attached the 1st plan file
Basic 50x4 Duplex.plan
By BIVOUAC
Hi, I'm new to Chief Architect and looking for someone that can set it up for me. I use Autocad ans have graphic standards that I would like to use and layouts (different size). I also which to have typical assemblies created (walls, foundation, floor, roof, etc) and will also be seeking for materials to set-up my main products (reference to specific products). Help on workflow can be an asset. Maybe stairs options.
As I am searching for services, the help is not required immediately and everything will be subject to a collaborative discussion. I need to get an idea of the budget and time I should allow. Maybe start with basics and progress along the way.
Thanks a lot in advance, Chief Architect seems very interesting!
