ChiefUserJJAS Posted May 12, 2018 Share Posted May 12, 2018 I am trying to recreate the design of our existing house and then I would like to add on a one car garage to the front and a room addition to the back. I have some pictures of our house that I have been using to compare along the way.I have tried every combination I can think of to get the roof design correct but when I get one section fixed it creates several other issues. As I work toward correcting those, the part I had corrected - is no longer correct! I have even removed the additional garage and room to see if I can then successfully recreate the roof. No luck! I have watched countless videos and read countless instructions (which is how I have got this far!), but I'm missing something - and I just can't find any instructions to solve it.At one point I had the roof over the front porch and the dormer completely corrected with the dormer area being the hip roof and the small gable area over the porch. I worked my way over to the garage side of the design and whatever I did created the flaw in the roof over the porch. Also the existing room over the garage is way off. I read about SWT and one point had HALF of the room and garage correct, but messed it up again as I was trying to get it the other half fixed. I also upgraded from Home Designer Pro 2017 to 2019 two days ago. Now I have some white X's and some black X's in the design. I assume they are "telling" me something is wrong - but cannot click on them, cannot find any documentation online telling me what they mean and how to use them to help fix the problem. ANY HELP IS APPRECIATED!!! Thank you! Home Plan - Copy What it looks like now - Copy.plan Link to comment Share on other sites More sharing options...
javatom Posted May 12, 2018 Share Posted May 12, 2018 Did you try the Home Designer Pro forum? Link to comment Share on other sites More sharing options...
ChiefUserJJAS Posted May 12, 2018 Author Share Posted May 12, 2018 Ummm? Is that a different forum than this one??? Link to comment Share on other sites More sharing options...
ChiefUserJJAS Posted May 12, 2018 Author Share Posted May 12, 2018 When I went to hometalk home designer user forum - then clicked on seeking services - this is where it took me. If there is a different link, can someone please send it to me? Link to comment Share on other sites More sharing options...
Chopsaw Posted May 12, 2018 Share Posted May 12, 2018 The X's appear to be roof intersection points that can be helpful when doing manual roof plane adjustments. They were generated by a setting in Preferences > Architectural > Roofs > "Automatically Place Roof Intersection Points" They can be deleted with the Delete Temporary Points tool You still have a long way to go but try selecting your front gable walls and open the DBX and go to the Roof tab and select "Auto Roof Return" Roof Type: "Full" Link to comment Share on other sites More sharing options...
