ajrare Posted May 8, 2018 Share Posted May 8, 2018 How best to draw this is Chief? Have attached picture. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 8, 2018 Share Posted May 8, 2018 Are you wanting to reproduce a 3D detail sheet with dimensions or build a custom bracket to use in your 3D drawings ? Link to comment Share on other sites More sharing options...
JiAngelo Posted May 9, 2018 Share Posted May 9, 2018 You can draw it fairly easily using slabs, then coloring the slabs. The bolts would take a little longer . To draw the text, I switched to orthagonal view, selected an isometric view, then copied region as a picture and special paste this image onto a CAD Detail window. The isometric places the object at a 30 degree angle. You can then draw lines and place some of the text (see attached) But I'm as curious as Chopsaw as to why? If that's the image you need, cut and paste it into chief and use it. Hope this helps. Link to comment Share on other sites More sharing options...
