Richard_Morrison Posted May 2, 2018 Share Posted May 2, 2018 This is a second floor addition to an existing house. I am struggling to find why the roof isn't cutting off the portion of the attic wall above the walkway. If I select the attic wall, the highlighted area shows the correct triangular gable, but there is still a portion protruding above the roof. Any suggestions? Attic wall problem.zip Link to comment Share on other sites More sharing options...
javatom Posted May 2, 2018 Share Posted May 2, 2018 I did not load your plan but I have seen this before. It can happen if the baseline of the roof is too low relative to the ceiling of the room under it. The attic wall gets confused. Link to comment Share on other sites More sharing options...
solver Posted May 2, 2018 Share Posted May 2, 2018 Make the front wall of the porch the same as the front wall of the garage, only invisible. Go to the 2nd floor and delete the gable wall -- the program will rebuild it correctly. 1 Link to comment Share on other sites More sharing options...
Richard_Morrison Posted May 2, 2018 Author Share Posted May 2, 2018 Thanks, Eric! That fixed it, and I doubt I would have stumbled onto this solution on my own. Link to comment Share on other sites More sharing options...
dshall Posted May 2, 2018 Share Posted May 2, 2018 my solution was to delete wall in 3d , wall auto came back but too short so then drag the left end out to the left and that worked without needing the invisible wall. Link to comment Share on other sites More sharing options...
Richard_Morrison Posted May 2, 2018 Author Share Posted May 2, 2018 1 hour ago, dshall said: my solution was to delete wall in 3d , wall auto came back but too short so then drag the left end out to the left and that worked without needing the invisible wall. That's actually what I did the first time, but I did it in a plan view. Maybe it works differently in a 3D view. Link to comment Share on other sites More sharing options...
