expodesigngroup
Changing Interior Wall View in Plan
Hi all,
I'm trying to change an interior wall from the defaulted yellow lines to simple black outlined wall, like a simple CAD rectangle (see attached):
Maybe I'm overthinking this, but can't seem to find the solution.
Please help
Either turn ON the “Walls, Main Layer Only” layer, or turn OFF the “Walls, Layers” layer.  One of those 2 should give you what I think you’re after.
You can change the Default Wall Type to be used in the "Defaults":
  • Edit > Default Settings > Walls > Interior Walls > Wall Type
Thank you Michael & Joe- unchecking "Walls, Main Layer Only" layer worked.  As did selecting "Deck/Railing Fence".
Unchecking the layer is only an easy couple steps away if I do want to show interior and exterior walls later.
Thanks bunches!!  :D
    27825
    ChiefDallas
    ChiefDallas
