johnny Posted April 17, 2018 Share Posted April 17, 2018 I'm working on plans with a large gable fascia/barge, but Chief is clipping the end off to flatten it out where there is an intersection to the corresponding "eave" fascia. Here is an example. Link to comment Share on other sites More sharing options...
kMoquin Posted April 17, 2018 Share Posted April 17, 2018 Zero out the Gable Fascia on the Structure Tab Create the gable trim with a shadow board specified as "Gable Only" Barge Boards.plan 2 Link to comment Share on other sites More sharing options...
johnny Posted April 17, 2018 Author Share Posted April 17, 2018 54 minutes ago, kMoquin said: Zero out the Gable Fascia on the Structure Tab Create the gable trim with a shadow board specified as "Gable Only" Barge Boards.plan Great Idea! Link to comment Share on other sites More sharing options...
johnny Posted April 17, 2018 Author Share Posted April 17, 2018 Worked like a charm - i can't thank you enough that was driving me crazy and i thought i might have to use p-solids. Link to comment Share on other sites More sharing options...
BryceEngstrom Posted April 18, 2018 Share Posted April 18, 2018 Thank Kevin. This has always bugged me too. While this is a big help, still bugs me how the whole fascia system works. I have never done gable fascia this deep that wasn't at least 1-1/2" thick, so I switched that. Still messy at the corner. Not really how things are typically built. Link to comment Share on other sites More sharing options...
Karl_B Posted April 19, 2018 Share Posted April 19, 2018 That works, thanks. How would you run the facia past the gutter to hide the end cap of the gutter? And, when you use a 2nd shadow board the top one runs past the bottom. Link to comment Share on other sites More sharing options...
kMoquin Posted April 19, 2018 Share Posted April 19, 2018 48 minutes ago, Karl_B said: That works, thanks. How would you run the facia past the gutter to hide the end cap of the gutter? And, when you use a 2nd shadow board the top one runs past the bottom. If the complexity got to that point I'd likely model it with psolids. Link to comment Share on other sites More sharing options...
country Posted April 19, 2018 Share Posted April 19, 2018 I would also like to know if we can extend the barge board to cover the end of the gutter. It's a very standard detail but I haven't been able to find a way to show it. Link to comment Share on other sites More sharing options...
BryceEngstrom Posted April 19, 2018 Share Posted April 19, 2018 14 minutes ago, kMoquin said: If the complexity got to that point I'd likely model it with psolids. Yeah, it's too bad rafter tails couldn't make that work. I tried it without success. Link to comment Share on other sites More sharing options...
BryceEngstrom Posted April 19, 2018 Share Posted April 19, 2018 Thanks for that. I was able to make it work now. What I learned was that the auto-framed barge rafter is labeled as sub fascia, and altering that doesn't work. You have to delete that and copy a regular rafter to be used as barge with a rafter tail. Link to comment Share on other sites More sharing options...
country Posted April 19, 2018 Share Posted April 19, 2018 Very nice! It will now look right in the renderings. Thanks. Link to comment Share on other sites More sharing options...
