2ND floor Level
Member Statistics
Similar Content
By PdoubleU
I am having Chief Architect X14 build floor framing and it keeps adding a double rim joist in the middle of a span. There is a Glulam beam in the middle of the garage floor, and a bearing wall for the other bearing line but I can't figure out why it is doing this. There are no walls above this floor system. First time posting so not sure what is needed to answer this question.
Floor question.plan
By MaggieTS
Hello!
I am very new to chief architect so I need some assistance.
I have a two story building where the ceiling height over the living space and part of the mud room has 9ft ceilings where the rest of the house is at 8ft ceilings. I have tried changing the floor height of the upper level but it just changes my overall ceiling height of the lower floor to 8ft.
In the image I have my file with the pdf of the design below. You can see the beam going down the center (to the left of the stairs). The area to the left has 9ft ceilings with a gable roof above, and the area to the right has 8ft ceilings with another level above.
How can I get the program to recognize I want to change the height over the stairs/part of the laundry/bedroom etc?
Thank you!
By BlackDiamond
I'm stumped....
I am working on a 4-plex on a sloped site so the floor levels of each unit are different. On the left end unit, when I try to change my standard basement floor level from -119 5/8" to -95 5/8" it works in all the 'rooms' but won't stay changed in the 1/2" space between the firring walls and the foundation walls. I've tried changing a firred wall to have no room definition so it included the 1/2" space but then the whole room goes back to the -199 5/8". I've tried everything I can think of and it just won't stay at -95 5/8".
I've moved the footings up to the proper location but as you can see in the .pdf view, the windows are 24" too low and the slab in that 1/2" space is 24" too low. I can't seem to figure out how to get it to appear accurately. I've included the plan file just in case. I'd appreciate any ideas.
Thanks
btw... I'm using CA Premier X12
firred space floor.pdf
Building 16-50 51 52 53.zip
By No1ZZTopfan
I would like to add the paint sample attached (med_sprinkle) and use it on the garage floor but each time I create the material it comes out as tiled. In addition, when it is solid its massive instead of regular size (see garage pic). Any suggestions/tips would be most grateful. Thanks.
Using CA12 on Win10Pro
By ChiefuserMathews
Hello, is there a way to display the ceiling elevation (height) on plan view, as we typically show them on architectural drawings?
