Handwerk_Arts Posted April 9, 2018 Share Posted April 9, 2018 I have a file I am working on the has an entry in the center. I have it mostly finished but cannot get the roof return correct. Also the Garage is -12" from the floor grade with mono slab. Every time i move it, it screws up something. Anyone have time to play with it? or can explain what I did wrong? The middle attic wall is floating, and would not generate a return, so I pulled it from one side. This one is being designed between HD pro 18 and X9 Carson_draft_zip.zip Link to comment Share on other sites More sharing options...
johnny Posted April 9, 2018 Share Posted April 9, 2018 I dont understand why the roof over that section can't be selected - and yet nothing is locked. edit Never mind, i see you are using auto dutch gable settings. Just make each side have the same baseline height - right now they are different. Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 9, 2018 Share Posted April 9, 2018 You cannot select auto-return roof planes in plan or camera views. DJP Carson Tims redesign xxx.zip Link to comment Share on other sites More sharing options...
Handwerk_Arts Posted April 10, 2018 Author Share Posted April 10, 2018 Thank you guys! Appreciate it. Link to comment Share on other sites More sharing options...
