foxriver32 Posted April 9, 2018 Share Posted April 9, 2018 I sent to plan a first floor framing wall plan. The walls are all labeled such as "Wall detail-14" When I highlight that wall and click on the "Open Wall Detail" icon, I get a 2d picture of the framed wall ....which is what I want. When I send that to plan, it IS NOT labeled with the "Wall detail-14" ....but has a label across the bottom ....something like "Wall Layer 4 - Viewed From Outside" it does this on all wall sections. I would like to have the wall labeled with the label from the plan on each section. Any idea how or what I need to do to make this happen ...I spend the last 2 hours screwing around trying to find out how ....could have just typed each on in! Almost forgot...running x9 Build 19.3.1 Thanks in advance Scott Link to comment Share on other sites More sharing options...
glennw Posted April 9, 2018 Share Posted April 9, 2018 You are looking at 2 completely different things. The wall label in plan view is the actual wall number. The Wall Layer # in the wall detail view refers to the wall framing layer number in the wall definition. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 9, 2018 Share Posted April 9, 2018 You need to use the %view.name% macro in the wall detail itself. Link to comment Share on other sites More sharing options...
foxriver32 Posted April 11, 2018 Author Share Posted April 11, 2018 Thanks Michael ....I tried it earlier and the macro did not work. Then, I read it again ...and found the small detail "in the wall detail itself" ....works like a charm! Must have wasted 3 hours trying to make that work..... sometimes I think I'm losing my mind Thanks again....works like a charm. Scott Link to comment Share on other sites More sharing options...
