3D view of Dormer Front Wall Missing
DC7Designs
I looked at your plan and it appears you need to explode your floating dormers to get the roof opening polyline to work correctly. I did adjust the opening polylines to fit inside the room space under the dormer.
Also as a tip for future roofing tasks :), turn off all the fill in your roof planes until you're set to send to layout. Makes it easier to work with and see whats going on. Also please set the roof base line over the framing layer of the wall it is going over. You will have less problems with getting the heights your after.
RSU_MOSS_ADDITION_3_help.zip
    30642
    oppguenard1
    oppguenard1
