DianeP Posted March 28, 2018 Share Posted March 28, 2018 Is it possible to close a roof opening that I decided needs to be smaller? The opening's rectangle that shows up on the floor plan disappeared once the roof was cut. Is redrawing the roof plane the only way to fix the problem? Link to comment Share on other sites More sharing options...
DianeP Posted March 28, 2018 Author Share Posted March 28, 2018 I've redrawn the plane but still would like to know for next time. Thanks! Link to comment Share on other sites More sharing options...
Chopsaw Posted March 28, 2018 Share Posted March 28, 2018 Make sure your "Roof, Openings" layer is turned on and you should be able to select and edit in 3D or floorplan, (roofplan) Link to comment Share on other sites More sharing options...
