walkthrough resolution
Kim-Prima
The resolution is set to your monitor's resolution for any kind of render other than Ray Trace, which can be set to any size and any resolution in its dialog box. For walkthroughs you can set a higher frame rate and shoot it at your PC's max resolution and monitor size.
40 minutes ago, Kim-Prima said:
Just to be clear - is it the active viewable window or the resolution of the monitor?
Yes,  both are factors.  Make your active window as large as possible for the best resolution.
