Layout reference grid for columns
Doug_N
I am working on a project that requires the plan view of each floor to have a reference grid that intersects at each column.   Is there a easy way to do this where each grid has an alpha callout at the top of the layout view and numeric callout along one or both sides.
Doug Norton
Whitby Ontario Canada
20 minutes ago, Doug_N said:
but that means two cameras for each and every column grid pair doesn't it?
Yes, but then they will remain constant on all floors.  Much less room for error.  You can also just use callouts with cross section lines and Copy/Paste in Place from floor to floor or use your Reference Dispaly and/or overlap views in layout but IMO, cameras are the most dependable, most flexible, and least error prone.
