Window label
Bob-Roraback
Absolutely possible.  I sent you a PM, but the short answer is that you would need to use one or more custom text macros that were formatted to your liking.  The best solution would depend on a number of factors but in essence, you would take the attributes available for a window (height, width, and rough opening settings in this case), add write a bit of code that would add those values together as necessary and then display those values in the desired format.
Thank you Eric, Joe and Michael. I have made the macro but I need help changing it to read only inches please.
This is what I wrote, I did the same for the width.   Thank you for any help, Bob
number = height + rough_opening_top + rough_opening_bottom
divisor = 1/16.to_f
a = ((number/divisor).round*divisor).divmod(12)
feet = a[0]
inches = a[1].floor
if a[1].modulo(1) == 0
fraction = ""
else
fraction = " #{a[1].modulo(1).rationalize}"
end
"#{feet}'-#{inches}#{fraction}\"".reverse.chomp("-'0").chomp(" 0").reverse.chomp("-0\"")
