Meltdown00 Posted March 14, 2018 Share Posted March 14, 2018 When I create a wall niche in X10 and add casing in the specification dialog box, the casing is not set against the wall unless you make the depth of the niche the same depth of the wall. Is there a way to change this or is this a bug? FYI: pretty new to Chief, started with X9, but don't remember having this problem before... Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 14, 2018 Share Posted March 14, 2018 Make sure you send it into to support or it won't get fixed Link to comment Share on other sites More sharing options...
Meltdown00 Posted March 14, 2018 Author Share Posted March 14, 2018 I have submitted a new case online. I have never done this before so I hope I did it correctly! Thanks solver, for the help. 1 Link to comment Share on other sites More sharing options...
cv2702 Posted March 14, 2018 Share Posted March 14, 2018 2 hours ago, Meltdown00 said: When I create a wall niche in X10 and add casing in the specification dialog box, the casing is not set against the wall unless you make the depth of the niche the same depth of the wall... Notice as well that even if the wall and the niche have the same depth, the casing is still not entirely flush? Link to comment Share on other sites More sharing options...
