QualicoreHomes Posted February 22, 2018 Share Posted February 22, 2018 In my door schedule it shows for a double door the following: 1x (for quantity) 60" x 80". I would like it to show 2x 30" x 80" and still have the rough opening show as 62" x 82 1/2". Is this possible? Link to comment Share on other sites More sharing options...
Chris_Kelly Posted February 22, 2018 Share Posted February 22, 2018 I'm not sure of a way to do that directly. It should say double hinged door, but if thats not enough I do have a couple ideas on work arounds: 1- Uncheck 'include in schedule' in door spec box. Create a wall way off the the side of the plan. Create a door the size you want and in the framing section make the r.o. the size you want. Then copy and paste so you have 2. Then your schedule will look right. Then get rid of the door label on the plan and use a callout to make it match the schedule. 2- Put text over the incorrect label on the schedule so it looks right. I'd be interested to see if there's a way to change the way it talks (for lack of better term) to the schedule directly. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 22, 2018 Share Posted February 22, 2018 Either use the comments field to indicate "double 30x80 door" or create a custom field in the OIP. 1 Link to comment Share on other sites More sharing options...
