Space Navigator Mouse
Greg_NY61
If anyone is using space mouse navigator, do you experience this issue when you set space navigator mouse it works fine. If you close and restart the program you have to go back into space navigator mouse settings and uncheck>recheck any setting in it and it will work fine again.
I guess the program is losing its ability to save the space mouse settings.
I use one and don't have that issue, however I have had the odd case where it stopped working while using Chief and I had to close Chief and restart it to get it to work again.  I find this mostly when changing between three Chief windows over thee monitors so there may be a glitch with doing that rapidly.
The  drivers for the space mouse have also had some odd issues over time. I had a case recently where after an upgrade the mouse would show as not connected and eventually I had to fully uninstall, clean up install remnants manually and re-install to get it back.
