Two cabinet schedules in one plan? The easy way?
GeneDavis
Easy ...well everything I know of is a kludge
IF the bath and laundry are adjacent AND you don't mind making them one room then it's kind of easy BUT if you
Since I most likely would not want to do that AND since there are more likely fewer cabinets there than in the kitchen?
Can block each cabinet in laundry and bath but now you have to fix the label that shows in the schedule AND the dimensions don't read according to the cabinet but are polar based on the block so that has to get fixed (easier with the new extra OIP fileds)
Other kludges I've had to use are -
  • convert one schedule to text then do the second one, or
  • use multiple plans and , since I use callouts for cabinet labels overlay the labels from one plan to another OR place my own callouts.
  • once, knowing I had an issue going in, I made one group of cabinets from Base and Wall cabinets and the other Tall Cabinets with custom counters.
Would be nice if it were possible to specify multiple rooms for a schedule.
