basilbabaa Posted February 14, 2018 Share Posted February 14, 2018 Anyone used scaling with X10 yet? in X9 I used to be able to send to layout as "no scale/scale to fit" and grab a corner of an object on a layout to click and drag to change the scale of the object. Now, grabbing corner handles reshapes the object on the layout page, which is a nice add, but I would still like to be able to drag the scale of an object on a layout page. Anyone know if there Is any way to still click and drag to dynamically scale objects on a layout? Link to comment Share on other sites More sharing options...
Chopsaw Posted February 14, 2018 Share Posted February 14, 2018 I had that same question not long ago and Michael helped out but it is a little more complicated than it was before unfortunately. "You can still do that by placing a point and using Rotate/Resize About Current Point. Just switch to the RRACP edit mode, place your point, and then use the Resize edit mode (X)." Link to comment Share on other sites More sharing options...
