Changing room to Deck creates slab
CA-User
Everytime I change a room to a deck, it changes the deck, but puts a slab under it. Can anyone tell me why this is happening? It must be a foundation setting but I can't see what is happening.
Also, we do mainly raised homes, so I am trying to set up a default floor system that has the internal setting, but the deck posts. I copied the Deck setting and modified it but it still puts a slab. Until now, I have been using a slab and putting a 1mm thick setting, and adding posts manually.
Do you have your Foundation set to Automatically build a Monolithic Slab Foundation?
Build>Floor>Build Foundation>
Also, as Rob mentioned,  it's good to have your Forum Signature filled in please, especially with the Software Version,
and of course a Name is nice too :) ..............see mine below in Blue for how to do that.
OK. I've worked it out. But I've noticed two things:
* the beams aren't spread to the edges of the main non-deck rooms. Is there a way to have them calculated from the edges inwards?
* I cant change the default settings for the Deck so it automatically adds a deck.
Does anyone know how to do this?
I've switched over from HDP and CA settings are a lot more complicated.
