roof pitch issue
Designer100
Auto won't work 100% of the time especially in that weird Corner created by the 45° Wall , looks like CA is Confused by something , so you will need to do some manual work.
Try copy and paste in place of the existing plane and change the pitch to 12 and use it for the upper pitch , you will need to resize it and rejoin it to the other roofs. ( shortcut is 2 key )
The original plane you can pull back so it is just over the Soffit Areas as needed....
P.S.
-You also have a number of reversed walls with blue siding showing inside , eg around the front door.
- also if you set the Alcove size to 100" in the Build roof Dialog the roof will build straight over the Alcove at the back. ( assuming you want that)
As you can see I didn't finish it, but ......
