ACADuser Posted January 22, 2018 Share Posted January 22, 2018 OK this is another situation where the porch beams (CC Lintels) need to tie into the exterior wall at a fixed location. See A & B The overhang & roof need to be at the edge of the beam as shown. Just because the soffit & fascias need to match. Columns need to center under the beam. This makes the floor not in the correct place for the column bases as shown in the picture. I guess you could drag the foundation out to make the floor larger, then the tile does not cover & the room size label is incorrect. How do you address these design situations? Also there is an issue with the soffit at A-C that I have not been able to fix. Use a 3D camera to look at the underside of the overhang. Thanks for your input. KTZ.zip Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted Friday at 02:00 PM Share Posted Friday at 02:00 PM Now is your chances to get a response... Wow, since 2018!! Please support the request below to update the porch floor... 1 Link to comment Share on other sites More sharing options...
Mark3D Posted 20 hours ago Share Posted 20 hours ago On 1/23/2018 at 6:16 AM, ACADuser said: OK this is another situation where the porch beams (CC Lintels) need to tie into the exterior wall at a fixed location. See A & B The overhang & roof need to be at the edge of the beam as shown. Just because the soffit & fascias need to match. Columns need to center under the beam. This makes the floor not in the correct place for the column bases as shown in the picture. I guess you could drag the foundation out to make the floor larger, then the tile does not cover & the room size label is incorrect. How do you address these design situations? Also there is an issue with the soffit at A-C that I have not been able to fix. Use a 3D camera to look at the underside of the overhang. Thanks for your input. KTZ.zip Have a look at this file to see if it will work i added a bit of extra porch and selected no roof over it to make eaves work Krutsinger.zip Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted 16 hours ago Share Posted 16 hours ago 3 hours ago, Mark3D said: Have a look at this file to see if it will work i added a bit of extra porch and selected no roof over it to make eaves work Hi Mark. Not sure if you noticed, but this posted back in 2018. I added the link above to a suggestion I am pushing. Would love to have you leave a comment and give me a thumbs up. Thank you for taking some time to show the work-around and prove my point that we need something to address this. Link to comment Share on other sites More sharing options...
