Joe_Carrick Posted January 17, 2018 Share Posted January 17, 2018 In X10 you can use the "Saved Plan Views" to actually name the Plan. Then by placing %view.name% in a Text Block or Rich Text Block you will have a Title for the Plan View. That allows you to name the View "Basement" or "Foundation Plan" or "Attic Plan" or "Roof Plan", etc. regardless of what Floor Level it's on. If you send the "Saved Plan Views" to Layout instead of the "Plan Levels" you will always have the correct title for the view in Layout. 2 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted January 17, 2018 Share Posted January 17, 2018 thanks Joe Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 18, 2018 Author Share Posted January 18, 2018 Here is my PLAN NAME & SCALE BLOCK - X10 for Plan View Titles. If the Layer Set Name includes the scale, the text scale in the title will be correct. Otherwise, it will display as "SCALE: 1" = 1'-0" The Graphic Scale will always be correct as long as the Block has not been resized. Once placed in a Plan, it can be displayed in any Layer Set just by making sure the "Text, Plan Name" layer is displayed. Plan Name & Scale Block - X10.calibz Link to comment Share on other sites More sharing options...
jscussel Posted January 18, 2018 Share Posted January 18, 2018 Thanks, Joe. Will give it a try. Link to comment Share on other sites More sharing options...
NRST8TRKR Posted January 24, 2018 Share Posted January 24, 2018 Thank you Joe, Have a great week, Ken Link to comment Share on other sites More sharing options...
