Sign in to follow this
SNestor
ATTIC WALLS
Quick question...can an attic wall be a "pony wall"?  I'm trying to create this gable end detail where there is a protruding decorative gable over a "siding covered" gable.  See attached pic.
This wall is designated as an "attic wall"...but, as you can see the roof is not trimming the wall off.
Check your wall definitions and make sure they are the same main layer thickness.  It shouldn't matter but I have seen it do odd things if they are not the same.
That pony wall problem is a bug, I think I reported several years ago.
But, just grab the top outside corner of the lower wall in drag it in a bit. It will snap into place -- sort of.
Some quick examples. Brick for the upper wall. 16" concrete.
ct1.thumb.jpg.4dc9676cc6ccf13dedbe25624320d578.jpgct2.thumb.jpg.cfc721123a05198631b162a9684317b6.jpg
It's easy enough to draw in a secondary wall, drag the bottom up and cap the bottom. The frieze even works -- sort of.
ct3.thumb.jpg.c1db595e2158d5eabb8a40bf0dc15597.jpgct4.thumb.jpg.bc5dc209807a1b4cca5aa85f952efd3f.jpg
Or, use a solid.
59 minutes ago, solver said:
Thanks Eric...I do these so rarely I forget how.  I just used a p-solid.  It’s easy and fast.
Also - as you suggested - just grabbing the pony wall and pulling it in corrected the attic wall...
    27450
    Elliot
    Elliot
  • Similar Content
    • By 9atatimer
      I'm using X11 premier on a mac -- I have an exterior garage wall (with a centered garage door) and a gable end -- I'd like to split the attic wall of the gable end into 3 parts -- the central region above the garage door, and the left and right, to have a different material above the garage door.
      I have Default Settings > Roof > Auto Rebuild Roof set to Off
      I have Default Settings > Framing > Automatically Build Floor and Ceiling Framing Off on all framing types.
      I have Default Settings > Walls > General Walls > Auto Rebuild Attic Walls set to Off
      If I delete the roof and ceiling planes with Build > Roof > Delete [X] and then use the Build > Roof > Build Roof ... dialog to rebuild the roof and attic from scratch -- I leave the Auto Rebuild Roofs set to Off, to be clear -- and then edit the resulting gable roof on the attic layer, I can split it twice to produce the three separate wall sections, but once I change the exterior material on any of the sections, the three wall segments get replaced with a single wall again.  The new wall has my selected material, but that does me no good as I need the distinct secgments.
      Anyone know what setting do I need to turn off to maintain the manually edited gable end?  Or is this a mac bug?
      Or, barring that, does anyone know what approach will let me give the desired finish detail (attached a pic of a freehand elevation)?
    • By KirkHodgson
      I'm looking to make my retaing wall larger than the terrain heights.
      In the instructions in this page, https://www.chiefarchitect.com/support/article/KB-00652/changing-the-height-of-a-retaining-wall.html
      I did all the steps, but the last point. In section/elevation, when I try to click the retaining walls, nothing happens. I don't get boxes or any selection at all.
      What is happening that I can't make this selection?
      I want to make my wall 6" above the grade/terrain elevation, and I want to drop the foundation of the wall by 24". How do I do this?
      Please assist.
      Thank you.
    • By MRMChief
      Happy Holidays everyone.
      I have a plan where I have a few places I need an exterior wall above a roof section, but a railing, or in one case, no wall below.  Is there a way to do this in Chief Architect X11?  The one opening in my screen shot shows some exterior molding, but no wall.  On the one that has the railing below it, I tried the lower wall type if split by roof, but I couldn't get it to show as a wall above and a railing below.  It was either only a railing or all wall.
      I am on a macbook pro..
      Thanks,
      Michael
    • By mprovost129
      Hi all. I'm fairly new to the software and have only been using it since October. I have a client who wants a wood framed chimney extruding from the middle of the roof up from the gas fireplace. I've tried a bunch of different options to make this work but can't figure it out. Can someone please tell me how to draw walls on top of the roof?
      Thank you!
    • By Designer100
      In 3d there is a wall sticking out. see jpeg attached. I cannot figure it out to remove.
      NEW-William_Dowdell_Dr.plan
