Ginkgohouse Posted July 27, 2014 Share Posted July 27, 2014 Good Afternoon... Looking to tighten up some dormer walls in the Master Bedroom on the second floor. 1) The walls that flank the cabinets need to only be 25" deep and then become "roof cuts walls at bottom" 2) On the exterior, the wall are switching to the "lower wall at roof butting" but the angle of the material does not match the roof plane and occurs 3" above the roof surface....weird. Any help would be appreciated. Thanks Mark https://www.dropbox.com/s/7ans9qdh8io8if8/Lochner%20-%20Help.plan Link to comment Share on other sites More sharing options...
rlackore Posted July 28, 2014 Share Posted July 28, 2014 I just selected the upper dormer wall in ortho view and dragged the bottom down. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 28, 2014 Share Posted July 28, 2014 looks like you tried moving the Dormer? Roof hole is outta place , is Auto Roof rebuild OFF/ you rebuild the roof yet or hit F12 perhaps? M. Link to comment Share on other sites More sharing options...
