Craig_G Posted January 6, 2018 Share Posted January 6, 2018 Trying to add some detail to a gable wall by extending it over a custom bay window structure. Ceiling on 2nd floor is ok, and the framing appears to be decent, but I just can't get the underside of the cantilever/boxing to cover. I've tried many tutorials on cantilevers, but it doesn't seem to apply to this scenario when automating the build. Is this possible, or do I just need to manually create the area? This current version was accomplished by creating a 3rd floor, and adding a new gable end wall. I also increased the overhang length. Thank you. Link to comment Share on other sites More sharing options...
dshall Posted January 6, 2018 Share Posted January 6, 2018 again, you should post the plan, but if I had to guess, I would of really turned that attic level into a REAL FLOOR WITH ROOMS, and then the cantilevered portion would have a finish defined by you. If you look at the underside you should see a finish material, but it will have no thickness, because of this if you have the framing turned on I bet you will see z fighting between the framing and the soffit material .... so the solution would be to turn off framing. Of course you can always add a psolid under the cantilever to serve as the finish. 1 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted January 6, 2018 Share Posted January 6, 2018 Listen to that young man, he is the master of all Chief. Link to comment Share on other sites More sharing options...
Craig_G Posted January 6, 2018 Author Share Posted January 6, 2018 I believe this article was my guide for the 3rd floor option: https://www.chiefarchitect.com/support/article/KB-00979/message-you-created-an-object-on-the-attic-floor.html I'm not exactly sure how I create a room in the attic that then allows me to automatically create the framing that creates the floor or 2nd/exterior ceiling for the overhang, since I can't define any rooms in the attic, just walls. I've attached the plan with what I was able to accomplish so far in the attic, but if you could guide me just a little bit further, it would be much appreciated. It could also be that I'm assuming auto-framing will work for this... when it won't. test.plan Link to comment Share on other sites More sharing options...
dshall Posted January 6, 2018 Share Posted January 6, 2018 That is the point of the extra floor. Attics will never have a room. So create the extra floor. if left office so I can’t look at your model Link to comment Share on other sites More sharing options...
Craig_G Posted January 6, 2018 Author Share Posted January 6, 2018 No worries. Here is the plan with the 3rd floor. test.plan Link to comment Share on other sites More sharing options...
Craig_G Posted January 7, 2018 Author Share Posted January 7, 2018 Works great. I still kept the 3rd floor for auto-framing purposes, but adding divider walls on the 2nd floor and making the space open did the trick. Thanks again. Link to comment Share on other sites More sharing options...
dshall Posted January 7, 2018 Share Posted January 7, 2018 21 hours ago, Craig_G said: No worries. Here is the plan with the 3rd floor. test.plan this is how you use the top floor to get a finish at the overhang. Notice the z fighting? framing and finish? turn off the framing and it should look good. 2 Link to comment Share on other sites More sharing options...
dshall Posted January 7, 2018 Share Posted January 7, 2018 Framing turned off. 1 Link to comment Share on other sites More sharing options...
Craig_G Posted January 7, 2018 Author Share Posted January 7, 2018 Ok, and this does not require extra members on the plan view. I guess the downside is that you cannot specify a material thickness? While we're at it. Can you help explain this gap? Link to comment Share on other sites More sharing options...
