myrtsbnye Posted December 14, 2017 Share Posted December 14, 2017 I am creating a curved roof over an entry and would like to know if there is a way to adjust both angles (eave and ridge or even the radius). Now when I adjust one the other angle and radius automatically adjusts to a number that I can't work with in this case. This roof starts as a 3/12 standard roof for 3' then curves up to the gable wall. I split the roof in two horizontally and have the first portion a standard 3/12 sloped roof and then the upper second portion to be curved. So, I would want the angle at the curve at the "eave" (in this case the intersection of the two slopes) to match the lower 3/12 slope (approx 14 deg) and have the angle at the ridge to be 30 deg. When I set the angle of the eave at 14 then set the angle at the ridge to 30 then angle at the eave changes to -1.9 degs. When I change one the other changes automatically. Is there a way to lock one angle like there is to lock slope and heights of a standard sloped roof? Link to comment Share on other sites More sharing options...
javatom Posted December 14, 2017 Share Posted December 14, 2017 I think what you are going for will require the curved part of the roof to be set to a steeper pitch. Try 12 then play with the radius until it gives you the look you are going for. Link to comment Share on other sites More sharing options...
glennw Posted December 14, 2017 Share Posted December 14, 2017 Are you looking for something like this. If not, post a sketch. Link to comment Share on other sites More sharing options...
javatom Posted December 14, 2017 Share Posted December 14, 2017 That goes to show you the importance of communication. I interpreted it more like the dormer on this house. Now I'm not sure what the op wants. Link to comment Share on other sites More sharing options...
