bgolfy Posted December 6, 2017 Share Posted December 6, 2017 Hi, I'm trying to build this kind of windows ... "inside" the wall.I tried to buil a railing wall with glases at the Top ... I also tried with a pony wall .. didn't work. Does anyone has an idea ? ... brilliant one ... thanks Link to comment Share on other sites More sharing options...
DavidJPotter Posted December 6, 2017 Share Posted December 6, 2017 I would resize the three wall poly-lines to the desired height above floor. Then place my windows casing and sills suppressed, then control-key the windows to the top of the reshaped walls. DJP 1 Link to comment Share on other sites More sharing options...
bgolfy Posted December 6, 2017 Author Share Posted December 6, 2017 I'm not sure to understand all (three wall poly-lines ??) ... but I will try when i get home. Thanks, Link to comment Share on other sites More sharing options...
bgolfy Posted December 6, 2017 Author Share Posted December 6, 2017 oops ... sorry ... maybe Moderators will move this post to Q&A. Solver, this is exactly what I'd like to build .... any link to follow ? Thanks, Link to comment Share on other sites More sharing options...
bgolfy Posted December 6, 2017 Author Share Posted December 6, 2017 Thank you solver ... i will go with that idea and see Link to comment Share on other sites More sharing options...
Kbird1 Posted December 6, 2017 Share Posted December 6, 2017 Something similar can be done fairly easily with invisible walls and a few Panels from DMDz's Nana Wall Library (attached) ...... I updated his (very) old free Library , and he has since provided a Single Panel version too... He also has an Updated full Library on his website along with other free and for sale items .... DMDz NanaWalls Updated 2017.calibzFetching info... DMDz_NanaWall Single Panel.calibzFetching info... 1 Link to comment Share on other sites More sharing options...
bgolfy Posted December 6, 2017 Author Share Posted December 6, 2017 On the left side, I have a problem with that (very) thin wall between the 2 windows and, on the right side, the angle, I cannot join properly the 2 windows ... tried to play with lot of windows parameters ... i will try Kbird1 files ... Thanks Link to comment Share on other sites More sharing options...
bgolfy Posted December 6, 2017 Author Share Posted December 6, 2017 Kbird1 ... DMDz's Nana Wall Library are doors. I'm trying to do that with windows as on Solver's previous post. Thanks by the way ... I will use them one day. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 6, 2017 Share Posted December 6, 2017 making corner windows is an issue , has been for many years , but you can force them to join by bumping them together , fast and hard usually . Not sure if the minimum window separation setting will help with the other issue or not? So why windows , not doors ? the photo seems to show a Door in the middle at least Link to comment Share on other sites More sharing options...
bgolfy Posted December 6, 2017 Author Share Posted December 6, 2017 I don't know if solver used doors or windows what they seems like ... see his previous post here. In my example I used Stucco wall with 300mm thick and on windows property I put Sash inset to 250mm to get what you see. Corners are my problem ... also joining the other window. The original photo shows 1st floor windows as you can see attached. Link to comment Share on other sites More sharing options...
bgolfy Posted December 6, 2017 Author Share Posted December 6, 2017 Thanks Solver ... will try this (perfect) solution ! Link to comment Share on other sites More sharing options...
Kbird1 Posted December 6, 2017 Share Posted December 6, 2017 Okay ...in the night time view I thought it was a Terrace with doors leading out , in the daytime shot I see it is Windows and an Open Sash (casement) Window... Link to comment Share on other sites More sharing options...
bgolfy Posted December 7, 2017 Author Share Posted December 7, 2017 It works ... Thanks again ! Link to comment Share on other sites More sharing options...
NRST8TRKR Posted January 24, 2018 Share Posted January 24, 2018 Mick, Thanks for posting the DMZ calibz files.Seem to have lost my along the way. Have a great week, Ken Link to comment Share on other sites More sharing options...
