REMDES Posted November 20, 2017 Share Posted November 20, 2017 Hello, I have researched help ,the training vids, and the forum still unable to get soffit at gable end to flush with the fascia.....snip pic and plan attached. rafters are 11 7/8" TJI , fascia is 2x6. thanks, Jerry 10100 work 11.16.zip Link to comment Share on other sites More sharing options...
Chopsaw Posted November 20, 2017 Share Posted November 20, 2017 I have not looked at the plan yet but what size is your sub fascia ? Link to comment Share on other sites More sharing options...
chief58 Posted November 20, 2017 Share Posted November 20, 2017 make your sub fascia the size of your facia or if you want it recessed a little make it shorter Link to comment Share on other sites More sharing options...
REMDES Posted November 20, 2017 Author Share Posted November 20, 2017 Chop & Ray, Fascia and sub fascia are the same size. The image is showing the soffit at the gable in line with the ceiling inside the room( rafters are 11 7/8" TJI.....) I cannot make it go away even if I reframe the roof with 2x6 rafters. Thanks Link to comment Share on other sites More sharing options...
Chopsaw Posted November 20, 2017 Share Posted November 20, 2017 When I opened the file it is not as extreme as your image in first post and all fascia and sub fascia is set to 5 1/2" which leaves the edge of the soffit exposed. The soffit sits on the bottom of the sub fascia so I would recommend as Ray did to make your fascia larger than your sub fascia if you want to hide the seam. Also your porch rooms that are under the overhangs should be set to "Use Soffit surface for Ceiling" or they will interfere. That should still work fine with your 11.875 TJI's. Outside wall of the living room needs to be reset to it's default top height also. Link to comment Share on other sites More sharing options...
