AndrewCass88 Posted November 16, 2017 Share Posted November 16, 2017 I'm having some issues with text. I have 2 basement plans one is just a layout and the other one is structural plan but when I add text to the one it shows in both how can I type in one set without it affecting the other sets? Link to comment Share on other sites More sharing options...
javatom Posted November 16, 2017 Share Posted November 16, 2017 Use different layer sets. Link to comment Share on other sites More sharing options...
AndrewCass88 Posted November 16, 2017 Author Share Posted November 16, 2017 Other than text do you recommend a layer? Link to comment Share on other sites More sharing options...
javatom Posted November 16, 2017 Share Posted November 16, 2017 Just place the text on a layer that is used for the view you want on the layout. For instance, floor framing has it's own layer. Put the type you want to show up for that view on just that layer. It will not show up on plan view because you would not have floor framing layer turned on for plan view. Link to comment Share on other sites More sharing options...
AndrewCass88 Posted November 16, 2017 Author Share Posted November 16, 2017 Thank you that was very helpful. Link to comment Share on other sites More sharing options...
Chopsaw Posted November 16, 2017 Share Posted November 16, 2017 The other option is to make a copy of your Text layer and create sub sections such as Text, Structural Text, Framing etc.. You will also typically need to add layers for CAD and Dimensions for the same reason. Link to comment Share on other sites More sharing options...
