Sign in to follow this
AndrewCass88
TEXT ISSUES
I'm having some issues with text. I have 2 basement plans one is just a layout and the other one is structural plan but when I add text to the one it shows in both how can I type in one set without it affecting the other sets?
Just place the text on a layer that is used for the view you want on the layout.  For instance, floor framing has it's own layer.  Put the type you want to show up for that view on just that layer.  It will not show up on plan view because you would not have floor framing layer turned on for plan view.
The other option is to make a copy of your Text layer and create sub sections such as Text, Structural  Text, Framing etc..  You will also typically need to add layers for CAD and Dimensions for the same reason.
    27466
    VCeffects
    VCeffects
