Robboulton Posted November 6, 2017 Share Posted November 6, 2017 I'm trying to find out how to change the send to layout scale in settings. Currently it is always 1:50 everytime I send a drawing to the layout sheet and I would like to change it to 1:100 Link to comment Share on other sites More sharing options...
Dermot Posted November 6, 2017 Share Posted November 6, 2017 The line weight scale is set for the layout under File->Print->Drawing Sheet Setup. You might need to change it in your default layout template as well. Link to comment Share on other sites More sharing options...
Kbird1 Posted November 6, 2017 Share Posted November 6, 2017 3 hours ago, Robboulton said: I'm trying to find out how to change the send to layout scale in settings. Currently it is always 1:50 everytime I send a drawing to the layout sheet and I would like to change it to 1:100 It uses the Default setting under Print >Drawing Sheet Setup>Drawing Scale.... at least it works for me ... try setting it to 100mm and see if the Send to layout Scale is now 100mm.... M. Link to comment Share on other sites More sharing options...
