Story Pole
QualicoreHomes
You need to select 'Marker Format' and change the Accuracy to 'smallest fraction'... then set the units to '-",   if ft, inches is the format you want to see. I had to reapply the story pole to allow the changes to show up (if they don't instantly change for you).
1 minute ago, QualicoreHomes said:
Thanks, that did it!! Not major, but is it possible to get those arrows and dimensions gone that appear vertically when I add an elevation dimension?
If you're talking about the inner dimensions, just go back into your story pole defaults and under 'general', toggle off the 'Inner Dimension' option.
