Joe_Carrick Posted July 18, 2014 Share Posted July 18, 2014 There is a setting in the Camera - 3D View Defaults for "Opaque / not-Opaque Glass". The problem is that it only works for Section/Elevation Cameras and then apparently only for glass in Windows and Doors placed in Walls. Other Glass Objects are always Opaque as are even Windows and Doors in Wall Elevations (Interior). Link to comment Share on other sites More sharing options...
Kbird1 Posted July 18, 2014 Share Posted July 18, 2014 I use this too but always check the "Auto adjust default Glass properties" box too ....seems to work , if I get your "drift" is the setting "sticky" in X6 ? Edit: Just had a quick play and now see what you mean , the window next to the shower is "clear" but the 3/8 standard glass in the shower stall is opaque.... didn't notice that before.... also noticed if I turn colour off I see the subway tile "lines" in the shower ( only above the glass) ,with colour on I only get a white square where the Subway tile is..... Link to comment Share on other sites More sharing options...
