Cathedral ceiling plane not complete
mtldesigns
Just spent an hour looking over past Q's and A's on this, not really finding a solution.
I am trying to continue a cathedral over a high ceiling entry to the back wall, but instead the ceiling plane follows the roof plan line. (Basically I want to continue the room plane back)  I have played with the many of the options I mentioned below, including putting in a ceiling plane but get nothing. With ceiling above room off, why doesn't a ceiling planes appear?  Elsewhere in this home where I have cathedral (via ceiling planes) I have no problems...
I have ceiling over room unchecked
I have ceiling default finish unchecked
I have checked and unchecked roof over this room
I have unchecked and checked Use Room Ceiling Finish
Checked and unchecked knee walls, because it kind is like a dormer
BTW, I cannot post plan, per contract obligations.  Builder specifically mentions this.
What you saw in the attached picts is what the entry looks like after I put my roof planes in and marked the rooms accordingly (no ceiling above room).  I posted below a butchered model just to show this area.  You can see I have a ceiling plane too, that doesn't show in the model.
Your help (or anyone's) will be appreciated.
898_Ponte_Vedra_Blvd_for_ca.zip
yes good morning.  In your first pict, I wanted to continue that ceiling plane all the way to the back wall.  In my attached model, there was a plane, but I cant see it in the model, so that's what was messing me up.  Is the 24" thk the trick?
