glennw Posted September 3, 2017 Share Posted September 3, 2017 I have a new user who is generating auto exterior dimensions. They are defaulting to Suppress Wall Widths for the exterior walls. I know I can manually open an existing dimension line and check the above. I know I can check Ignore Interior Walls in the Auto Exterior Dimension Defaults. Does anyone know if there is a default for this setting. Every time I do an Auto Exterior Dimension, the exterior wall widths are displayed. Every time she does an Auto Exterior Dimension the exterior wall widths are not displayed. Any ideas? Link to comment Share on other sites More sharing options...
Chopsaw Posted September 3, 2017 Share Posted September 3, 2017 PLAN DEFAULTS>Dimensions> Auto Exterior Dimensions> Locate Objects> Wall Options> Select "Both Wall Sides" Link to comment Share on other sites More sharing options...
glennw Posted September 3, 2017 Author Share Posted September 3, 2017 Chop, I don't think that is it. I probably didn't express the problem properly. She is getting the extension lines to both sides of the exterior walls. But, she isn't getting the dimension text for the external wall thickness. Its the same as having a Blank Segment. Link to comment Share on other sites More sharing options...
Chopsaw Posted September 3, 2017 Share Posted September 3, 2017 So not like this ? Link to comment Share on other sites More sharing options...
glennw Posted September 3, 2017 Author Share Posted September 3, 2017 Chop, No. The 51/2" dimensions are not showing, but the extension lines are. Like the top dimension here: Link to comment Share on other sites More sharing options...
Chopsaw Posted September 3, 2017 Share Posted September 3, 2017 Does that have anything to do with Minimum Area ? Link to comment Share on other sites More sharing options...
