johnny Posted August 5, 2017 Share Posted August 5, 2017 When you have a door and window next to each other in Chief, but want the "bumping" to tie the headers together, is there a way to eliminate the overlap lines? I know you can mull together, but then the middle casing ends up incorrect. Id love to be able to keep the doors/windows separate (as they are in real life) and get a single-piece lintel (casing header). Link to comment Share on other sites More sharing options...
glennw Posted August 5, 2017 Share Posted August 5, 2017 9 minutes ago, johnny said: but then the middle casing ends up incorrect. How so Johnny? Link to comment Share on other sites More sharing options...
johnny Posted August 5, 2017 Author Share Posted August 5, 2017 18 hours ago, solver said: No lintel on windows. Extended lintel on door. genius. Link to comment Share on other sites More sharing options...
johnny Posted August 5, 2017 Author Share Posted August 5, 2017 18 hours ago, glennw said: How so Johnny? Hey Glenn - when you mull units together the middle casement ends up as a mullion more than casement - visually as well. (added) Playing around with this more, I guess this is an issue more when you have a clerestory above as well (which i often do in the entry). Not to much in the instance I show above - I agree, BUT the other problem is the window still becomes no longer an option, and there are some funny problems with trim being placed under the door. Link to comment Share on other sites More sharing options...
