wncbw7 Posted August 4, 2017 Share Posted August 4, 2017 I am missing a small piece of ceiling above the glass shower wall, I have pulled this wall down so there is an air gap, but even when the glass wall meets the ceiling I end up with a piece of unfinished ceiling the thickness of a 4" wall. What gives, can I fix this other than adding a polyline solid to cover up the missing ceiling??? THANKS Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 4, 2017 Share Posted August 4, 2017 13 minutes ago, wncbw7 said: What gives, can I fix this other than adding a polyline solid to cover up the missing ceiling??? THANKS Post your plan please There are a number of difrerent fixes or possible problems...the easiest fix may be to set your shower wall as "no room definition" and then click on rebuild 3d..though this isnt a solution to the problem it may be a quick fix Link to comment Share on other sites More sharing options...
wncbw7 Posted August 4, 2017 Author Share Posted August 4, 2017 plan attached hugo master bath plan.plan.zip Link to comment Share on other sites More sharing options...
Chopsaw Posted August 4, 2017 Share Posted August 4, 2017 Nice work Eric. I looked at the plan earlier and could not find an automatic solution in X8 so it looks like that might just be the best option. Also the glass shower walls can be pulled back with the Edit Wall Layer Intersections tool so they look better in 3D. Link to comment Share on other sites More sharing options...
wncbw7 Posted August 5, 2017 Author Share Posted August 5, 2017 Great. Thank you. Link to comment Share on other sites More sharing options...
