HeatherL Posted July 31, 2017 Share Posted July 31, 2017 Hey guys, this is the first time I have posted one of these. So I am using Home designer Pro 2018. I have been having issues getting furniture to sit on top of rugs. I tried to do the whole send to front and send to back but that does absolutely nothing. Basically, when I try to put anything on top of a rug, it just pushes the rug out without putting my selected object on top of it. It does it with toilets and toilet rugs, bedroom furniture, dining room furniture, essentially things that would generally go on top of the rugs. Link to comment Share on other sites More sharing options...
Greg_NY61 Posted July 31, 2017 Share Posted July 31, 2017 Look at the rug thickness and set that amount "Off The Floor" distance on the furniture. So if your rug is 3/4" open DBX on your furniture and set 3/4 off the floor height 1 Link to comment Share on other sites More sharing options...
HeatherL Posted July 31, 2017 Author Share Posted July 31, 2017 Oh, sorry for posting to the wrong forum. Got a pretty good answer though. I didn't even think of that. Thanks guys! Link to comment Share on other sites More sharing options...
Dermot Posted August 1, 2017 Share Posted August 1, 2017 I'm a little bit unclear on your problem... If the problem is that when you try to place one library object on top of another, the program always wants to select the first one instead of placing the new one, then you should try placing the object to the side and then move it on top of the first one. Sometimes holding down the control key helps with this because it disables the bumping/pushing and allows you to move the object freely. If the problem is that the objects won't display in the correct order in your plan view, you can control this with the Draw Order Edit Tools. Basically, you can move any object into any drawing group so that it draws in front or behind other objects. You can also move objects around within their group. More info can be found in the reference manual. Link to comment Share on other sites More sharing options...
