Circular Roof Opening
JonBDesigns
Hi Everyone!
Is there a way to create a circular or curved roof opening?
As far as I can tell, it is only possible to create roof openings that straight or angular (triangle, square etc.). I am trying to create a glass geodesic dome on top of a roof.
Thank you for the help!
Peace,
Jon
Create a circle, convert that circle to a polyline, and then either convert that polyline to a hole or use boolean operations (polyline subtraction) to cut the hole.
You can also simply draw a square hole and then fillet the corners to make a circle.
I'm away from my computer and I'm just rattling off some ideas from memory so there may be other ways but those are a couple that come to mind.
