Sign in to follow this
jennyultimate
Creating Terrain Perimeter from 3D Object
Hi,
I used SketchUp's  Geo Location feature with the intent of turning the location into a 3D object for Chief. From Chief, I imported the .dae file and it looks nice in 3D. However, I need to create a terrain Perimeter. when I use the create terrain perimeter, it just lays out a flat terrain. I want to be able to turn the .dae import into the terrain perimeter. Is that possible?
I don't believe so. However, I've used this technique successfully. When importing the dwg into Chief, make sure you use Convert Selected Layer(s) to: Elevation Data. Some manual cleanup is usually necessary.
    27342
    KOHANsen
    KOHANsen
