Open Below space leaves ceiling open
Gawdzira
My stairwell zone set up as an "Open Below" room won't let me put in a ceiling. I tried adjusting the height of the room ceiling and tried overriding the ceiling with a custom ceiling plane. I know I can make a polyline solid to fill the space but why should I do that? What is causing my lack of ceilinginity?
EGT_dd_v1a.plan
You sure are a funny guy Alan, I down loaded your plan just for kicks because as I said about 20 minutes ago I am no stair expert but it must be getting late even in California because you have the Ceiling Finish turned off for your Open Below Room.  I just hit the default for (J) and it was all fixed.
Chopsaw, thank you. I kept repeatedly clicking and unclicking "Ceiling over this Room". I don't know if I have ever unchecked Ceiling Finish. I wonder if this carried over from the previous room type since I added this space where the deck was and then had to change the room type?
