adding lites to ext. door
JBOTXM
Chief doesn't allow lites on all door types.  I think it only applies to "Glass Doors" but you can set the bottom "Panel Frame" to be different than the side and top frames so you get the appearance you want.
The other option would be to create a Library Door with the Lites you want.
2 hours ago, Chopsaw said:
Thanks for that information Joe.  Here is a link to my tutorial for placing lights into doors that chief does not allow them automatically if that is required, without starting from scratch to build a paneled door.
https://chieftalk.chiefarchitect.com/topic/9475-custom-door-symbol/?do=findComment&comment=83041
Very helpful thanks chopsaw.
You are quite welcome and that is what this forum is all about. If you read from the beginning of the linked thread you will notice that I started out with essentially your problem and decided to share the solution once I figured it out with the help of others.  Chief can do a lot of things that are not always obvious.
