Scottb Posted June 22, 2017 Share Posted June 22, 2017 any easy way to make stairs like this? Flare option doesn't work. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 22, 2017 Share Posted June 22, 2017 I don't see any attached image Scott. Link to comment Share on other sites More sharing options...
Scottb Posted June 22, 2017 Author Share Posted June 22, 2017 it should be there now. thanks. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 22, 2017 Share Posted June 22, 2017 Scott, How is the Flare Tool not working for you? Are you using the edit handles after selecting that tool to adjust the ends of the stair? 1 Link to comment Share on other sites More sharing options...
Scottb Posted June 22, 2017 Author Share Posted June 22, 2017 Yes I am. but the flare option only lets you go so far. if you pull it too much, it rounds it. Need to go from 6' wide to 9' wide. Link to comment Share on other sites More sharing options...
Scottb Posted June 22, 2017 Author Share Posted June 22, 2017 I played with it more. I think I can get it to work. Link to comment Share on other sites More sharing options...
Scottb Posted June 22, 2017 Author Share Posted June 22, 2017 maybe not. I want a nice straight line from 6' to 9'. it keep wanting to curve them. is there a way to turn that option off? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 22, 2017 Share Posted June 22, 2017 Try using the technique Dennis mentions in this thread. I think its probably the best option... Link to comment Share on other sites More sharing options...
Scottb Posted June 22, 2017 Author Share Posted June 22, 2017 I'll try that. Thanks Link to comment Share on other sites More sharing options...
Scottb Posted June 22, 2017 Author Share Posted June 22, 2017 Winders don't work. You would think Chief would make this a lot easier. The stairs don't turn which is what I can do with a winder. I just need to angle each step. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 22, 2017 Share Posted June 22, 2017 On 6/22/2017 at 4:14 PM, Scottb said: Winders don't work. You would think Chief would make this a lot easier. The stairs don't turn which is what I can do with a winder. I just need to angle each step. Expand Winders will automatically cut to the walls... Link to comment Share on other sites More sharing options...
Scottb Posted June 22, 2017 Author Share Posted June 22, 2017 ok. I'll have to play with that. What level is your deck on and what level did you build the invisible walls.? Link to comment Share on other sites More sharing options...
Scottb Posted June 22, 2017 Author Share Posted June 22, 2017 Got it. Thanks for your help. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 22, 2017 Share Posted June 22, 2017 On 6/22/2017 at 4:43 PM, Scottb said: ok. I'll have to play with that. What level is your deck on and what level did you build the invisible walls.? Expand Doesnt really matter what level you build on as long as your height are set correctly. The stairs and walls should just be on the same level as each other. Also... You don't necessarily need to use invisible walls. You could use any wall type (visible or not and displayed or not). You just need to have walls of some sort in order to utilize that automated winder behavior. Link to comment Share on other sites More sharing options...
