making stairs wider at the bottom. not flare
Scottb
7 minutes ago, Scottb said:
Winders don't work.  You would think Chief would make this a lot easier.  The stairs don't turn which is what I can do with a winder.  I just need to angle each step.
Winders will automatically cut to the walls...
16 minutes ago, Scottb said:
ok.  I'll have to play with that.  What level is your deck on and what level did you build the invisible walls.?
Doesnt really matter what level you build on as long as your height are set correctly.  The stairs and walls should just be on the same level as each other.  Also...
You don't necessarily need to use invisible walls.  You could use any wall type (visible or not and displayed or not).  You just need to have walls of some sort in order to utilize that automated winder behavior.
