chiefPT
Terrain breaks, any advice on how and where it is best to use it?
Hi all
First of all thanks for all the help you guys are offering here. It helps very much.
I am wanting to learn terrains and I am having some issues when I try to use terrain breaks. How can I apply it without having the weird cut that splits the terrain.
Any advise would be much appreciated.
Thanks in advance.
1 hour ago, chiefPT said:
Hi all
Thanks in advance.
terrain breaks can be unpredictable at times.  I do not think there is one answer that fits all situations.  There seem to be different solutions for different scenarios.
The advice I can give is to post a plan with the problem you are having and somebody may have a solution for your particular situation that helps us all.
I recommend that you create a terrain plane and then have that terrain break at differing height changes to get a feel for what works and what does not work. I agree with Scott in that specific advice can only be offered after evaluating a particular plan file along with an understanding of what the wanted result is to be. It depends upon how much the terrain modulates (changes) and surrounding terrain. There is a trial and error to this in terms of finding just the right combinations of objects and values that work together to cause a specific result.
The general advice I always offer is to make one change and then evaluate that change in camera views until you are satisfied with the results and then make another change, etc. Avoid making a lot of changes in terrain objects and then evaluating the results as then it is harder to know what change caused the viewed result.
Thanks, have watched a video you posted earlier " terrain break to billemery" and that was helpful. I have seen also in your video how unpredictable it could be at times.
I have read an article in knowledge base explaining about terrain break tool, cool article.
David
Thanks for the advise too. Just learning...
    27991
    KPawlyshyn
    KPawlyshyn
  • Similar Content
    • By MN_JohnH
      I know this has been talked about before but I can not find it and I can't figure out how to do it again.
      I have a house drawing and I have the terrain drawn and I would like to orient the house differently on the terrain. I want to keep my house drawing square with my plan so it would need to be the terrain itself that has to rotate. I can rotate the terrain perimeter but that doesn't rotate the elevation lines etc. When I select the perimeter and all the elevation lines, i am not able to rotate the whole thing.
    • By decorators3
      Hi
      I am building a foundation but in camera view there is a hole under the foundation but no terrain.. ???!!
    • By Steve77
      Hi There,
      I am a current chief architect user and have a question in regards to the contour tool and driveway tool.
      I have a plan that has a sloping site that I am trying to accurately portray in 3d for both client and the Local Council.
      From the road front the site slopes left to right and from the back to front.
      (I have attached Images shown what I currently have)
      My question is there something that I am missing I have also tried in elevation converting/extracting a polyline solid but it doesn't quite work.
      I have attached a link to the 3d viewer but can add a plan if need be.   https://3d-viewer.chiefarchitect.com/go?share=503392208525732
    • By ericepv
      I am trying to create a sunken patio in sloping terrain. The problem I am having is getting a smooth drop in the grade of the lot without distorting the patio which needs to remain flat. The attached sample file shows what I am trying to achieve with the grey circle representing the area where he patio will be. I tried to subtract this area from the terrain perimeter but found that I cannot subtract and object from terrain like I can with a polyline solid. I've been back and fourth with tech support but so far they have not been able to find a solution.
      Any ideas?
      Sunken Patio in Sloping Terrain.zip
    • By MN_JohnH
      How do I fix the terrain under this covered screen porch?
