Flemish bond bricks
COLONIAL-CHIEF
There is a Flemish Bond hatch pattern in the ChiefBrick.pat file.
Look for the 20-BRK_Flemish pattern.
You get there by going to the Fill Style panel...Pattern...Type:...Custom (down the bottom) of the list.
Select the above .pat file with the Browse button.
29 minutes ago, COLONIAL-CHIEF said:
Glenn -  I assume you are you suggesting I draw a polyline over the walls in elevation view and fill it w/ 20-BRK hatch pattern?  Is there a way to get the pattern on to the actual wall type?
You can click on your material's pattern tab and use the same pattern there.  This will work for all vector views.  For standard views and ray traces however you would need to find a Flemish Bond texture
