HumbleChief Posted May 16, 2017 Share Posted May 16, 2017 I'm sure this has been suggested before but I found this tip from Glenn Woodward to somehow make sense to me suddenly. I hope it helps others and any tips regarding same MUCH appreciated. 1 Link to comment Share on other sites More sharing options...
glennw Posted May 17, 2017 Share Posted May 17, 2017 Larry, I really hope it helps because I know that at times you have struggled with the dbx. Here is a little bit more https://www.screencast.com/t/mFdmC0nLjh7o 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 17, 2017 Share Posted May 17, 2017 Thanks to both Larry and Glenn. Those were very good videos to show how to deal with room heights. As I recall, it's possible to use the perspective views to adjust the rooms as well. Link to comment Share on other sites More sharing options...
HumbleChief Posted May 17, 2017 Author Share Posted May 17, 2017 Thanks again for some clarification Glenn. It's a great help. Link to comment Share on other sites More sharing options...
glennw Posted May 17, 2017 Share Posted May 17, 2017 26 minutes ago, Joe_Carrick said: As I recall, it's possible to use the perspective views to adjust the rooms as well. Joe, Yes, can be done in perspective view. You need to select the room by the back wall, not the floor. And it really gets hard to manipulate things, especially if they are internal rooms. The ability to edit platform heights (along with being able to edit location of walls etc) in a perspective view can be useful for massing studies, but I don't really think it is practical for day to day work. Link to comment Share on other sites More sharing options...
