Chopsaw Posted May 11, 2017 Share Posted May 11, 2017 Does anyone have a high res image or material file for PSL ( Parallel Strand Lumber ) that they would be willing to share or provide a link for? I have found several images I could use for end grain but will only have a few of those exposed. No luck searching for a flat image of the side. I would prefer a sanded, filled, stained, and sealed version but based on my searches today would settle for anything that looks good. My next project features exposed PSL Timber frame. Thanks In Advance. Link to comment Share on other sites More sharing options...
justmejerry Posted May 12, 2017 Share Posted May 12, 2017 you try the Weyerhaeuser site, may have to crop out of one of the shots they have? If I was going to Rona tomorrow, I'd snap you a couple pics, they have a display with all the different engineered offerings. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 12, 2017 Author Share Posted May 12, 2017 Thanks Jerry I do have a call into Weyerhaeuser, so if they come through with something good I can maybe share it here but so far lots of stuff like this that would be pretty difficult to make a material file with unless it was 3D and I could turn it. 1 Link to comment Share on other sites More sharing options...
rlackore Posted May 12, 2017 Share Posted May 12, 2017 Here are two options in a library: PSL.calibz Material PSL 1 Material PSL 2 Here's a zip of the texture files: Textures.zip Link to comment Share on other sites More sharing options...
DRAWZILLA Posted May 12, 2017 Share Posted May 12, 2017 I've been trying to get Chief to add a "PSL" to the beam labels forever. Others too like "LVL", GLB. I guess I have no pull with them like Scott does. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 12, 2017 Author Share Posted May 12, 2017 5 minutes ago, DRAWZILLA said: I've been trying to get Chief to add a "PSL" to the beam labels forever. Others too like "LVL", GLB. I guess I have no pull with them like Scott does. Don't give up Perry, If we all work together it will happen. I got a note back from my tech inquire today. " Thank you for contacting Technical Support, I checked with content and they currently are working on adding Parallel Strand Lumber to the core catalog, and one of these days you will see this new material in the Library Browser. " I have also been pushing for the ability to assign default materials for each type of framing member. No response on that yet though. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 13, 2017 Author Share Posted May 13, 2017 15 hours ago, rlackore said: Here are two options in a library: Thanks Robert, Those will work fine for now and for structure details until I can find a finished version. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 14, 2017 Author Share Posted May 14, 2017 Thanks Eric, Where did you find those? Did you photoshop them? Link to comment Share on other sites More sharing options...
